K&S Brass Tubing 12" long (305mm)
Product ID ks-brass-tb-12
Price: $0.99
K&S Brass Tubing. These are sold a in single 12" (approx 305mm) length. The sizes are the outside diameter (od).
This tubing is used when building a stuffing tube system in a boat. There are two traditional ways to build a stuffing tube using a flex cable, either with a Teflon liner installed into the brass tube OR without a Teflon liner. If you search online you will find pros and cons to both solutions.
Below you will find the recommended brass stuffing tube sizes for both methods.
Size when used with NO Teflon stuffing tube
Flex Cable Size
Required Stuffing Tube
.098" (2.50mm)  Part # 8128 5/32"
.130" (3.30mm)  Part # 8129 3/16"
.150" (3.81mm)  Part # 8130 7/32"
3/16" (4.75mm, .187" )  Part # 8131 1/4"
1/4" ( 6.37mm, .250" )  Part # 8133 5/16"
Size when used with a "Teflon" stuffing tube.
Flex Cable Size
.098" (2.50mm)  Part # 8129 3/16"
.130" (3.30mm)  Part # 8130 7/32"
.150" (3.81mm)  Part # 8131 1/4"
3/16" (4.75mm, .187" )  Part # 8132 9/32"
1/4" ( 6.37mm, .250" )  Part # 8134 11/32"
Includes:
(1) Length of Brass Tubing Only. NO teflon included.
Note:
- Picture 2 & 3 for reference only.
- Tubing will telescope into the next larger or smaller size. This is useful for making bushings, sleeves, or drive shafts. See pictures 2 & 3.
- Loctite sleeve retainer glue is recommended for gluing brass tubing together.
- The 3/16" pn# 8129 is often used for 4mm solid shafts in scale(low rpm) applications.
- The 5/32" pn# 8128 can be used a a 1/8" to 4mm prop adapter.
- A piece of 8128 (1/8") and 8129 (3/16") can be combined to make a 1/8" to 3/16" adapter.
« Previous | Next »
OSE Raider M40 Hull (39.75" 1010mm)
1 of 7
Product ID ose-Raider-M40
Price$299.99
Speedmaster 21 Strut : Hydro
1 of 4
Product ID ros-spdss-001
Price$29.95
Speedmaster 21 Strut : Mono
1 of 2
Product ID ros-spdss-002
Price$28.95
OSE .098 cable with 1/8" prop shaft
Product ID ose-cable-098L
Price$24.99
Speedmaster Sport 20 Strut
1 of 3
Product ID ros-spds-005
Price$29.95
OSE .130 cable with 4mm to 1/8" stepdown prop shaft
Product ID ose-cable-1085
Price$29.99
OSE .130 reversed (right) cable with 4mm to 1/8" stepdown prop shaft
Product ID ose-cable-1085-R
Price$29.99
Speedmaster Large 3/16" (.187) Strut
Product ID ros-spds-007
Price$29.95
Linkage Rod Boots Medium
1 of 2
Product ID ose-80452
Price$2.95
Speedmaster Large 1/4" (.250) Strut
Product ID ros-spds-008
Price$29.95
TFL 1/4 Drive
1 of 4
Product ID tfl-503b98
Price$79.99
TFL 1/4 Inch Drive with skeg
1 of 4
Product ID tfl-503b98-a
Price$79.99
TFL Arenson Outdrive with 1/4 (6.35mm) Prop Shaft
1 of 4
Product ID tfl-523b43
Price$249.99
Linkage Rod Boots Large
1 of 2
Product ID ose-80454
Price$2.95
OSE .150 cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150L
Price$32.99
Speedmaster Extended 1/4" Strut
Product ID ros-spds-010-250
Price$34.95
High performance Sevan Outboard
1 of 5
Product ID bel-flex-2042
Price$169.99
OSE .150 cable with 3/16" : 3.00" long prop shaft
Product ID ose-cable-150L-xL
Price$32.99
Cable alignement T bar for Zenoha Engines
1 of 5
Product ID tfl-526b36
Price$48.99
Speedmaster 1/4" CAT: Extended Strut Assembly: Flat Bottom
Product ID ros-SPDS-012-250F
Price$38.95
Speedmaster 1/4" CAT: Extended Strut Assembly: Round Bottom
Product ID ros-SPDS-012-250R
Price$38.95
Large Offset Catamaran Strut and Rudder System
1 of 4
Product ID tfl-502b36
Price$69.99
3/16 (4.75mm) Strut for Large Offset Catamaran Strut System
1 of 3
Product ID tfl-502b36-a
Price$14.99
OSE .150 reversed (right) cable with 3/16" prop shaft 2.25" long
Product ID ose-cable-150R
Price$32.99
OSE .150 reversed (right) cable with 3/16" : 3.00" long prop shaft
Product ID ose-cable-150R-xL
Price$32.99
Speedmaster Cat Skeg Strut Assembly - Small
1 of 2
Product ID ros-spds-017-SK
Price$34.95
Speedmaster 1/4" Gas Strut and Square drive cable system
1 of 4
Product ID ros-SPDSD2-G250
Price$159.95
Speedmaster Stinger Strut
1 of 7
Product ID ros-stinger-str
Price$39.95
TFL Aluminum CNC Adjustable Strut for 3/16 (4.76mm) Shaft
1 of 3
Product ID tfl-503B23
Price$14.99
TFL Aluminum CNC Adjustable Stinger drive for 3/16 (4.76mm) shaft
1 of 2
Product ID tfl-503B70
Price$29.99
TFL Aluminum Remote Controllable 1/4 Stinger Strut
1 of 3
Product ID tfl-503B92
Price$69.95
OSE .187 (3/16") cable : drive dog : bullet nut : 3/16" prop shaft : 3.25" long
Product ID ose-cable-187-XL
Price$39.99
OSE .187 (3/16") cable with 3/16" prop shaft 3.25 long
Product ID ose-cable-1190
Price$27.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
K&S Aluminum Tubing 12" long (305mm)
1 of 3
Product ID ks-aluminum-tb-12
Price$0.99
K&S Stainless Tubing 12" long (305mm)
Product ID ks-stainless-tb-12
Price$3.50
OSE 1/4" cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290
Price$34.99
OSE 1/4" reversed (right) cable with 1/4 to 3/16 step down prop shaft x 32" (800mm) Long
1 of 2
Product ID ose-cable-1290-rev
Price$34.99
SpeedMaster small inline skeg strut and single pickup rudder assembly
1 of 3
Product ID ros-spdrs-002a-sng-2
Price$89.95
SpeedMaster small inline skeg strut and dual pickup rudder assembly
1 of 2
Product ID ros-spdrs-002a-du-2
Price$89.99
OSE 1/4" cable with 1/4" prop shaft x 30" (760mm) Long
Product ID ose-cable-1295
Price$32.99
OSE 1/4" reversed (right) cable with 1/4" prop shaft x 30" (760mm) Long
Product ID ose-cable-1295-rev
Price$32.99
Micro Strut
1 of 4
Product ID ose-83046
Price$11.95
Strut for 45 Inch (1150mm) catamaran 140mm long
1 of 3
Product ID tfl-503b85
Price$59.95
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$3.99
2mm wire drive with 4mm shaft
Product ID tfl-510B02
Price$7.99
2mm wire drive with 4mm threaded end
1 of 2
Product ID tfl-510B03
Price$7.95
Teflon Liner 20 Foot bulk package (600cm)
Product ID oct-teflon-240
Price$39.99
1/4 Adjustable Stinger Strut
1 of 6
Product ID tfl-503b82
Price$46.99
Z21 Strut for Jae-21
Product ID zip-3495
Price$24.95
OSE Stuffing tube clamp with oil fitting
1 of 2
Product ID ose-83037
Price$4.99
OSE Stuffing tube mount with oil fitting
1 of 3
Product ID ose-83010
Price$14.95
OSE Carbon Stuffing Tube Mount
1 of 2
Product ID ose-83029
Price$3.95
K&S Tubing Bender
Product ID ks-321
Price$4.57
4mm Shaft with 4mm flex cable
Product ID tfl-510b24
Price$14.99
Retaining Glue Loctite 603
Product ID mc-loc603
Price$21.99
Retaining Glue Loctite 638
Product ID mc-loc638
Price$24.99
RSX310 FE: Wood Outrigger Kit with Fiberglass Cowl (31" 787mm)
1 of 4
Product ID ml-rsx310
Price$199.99
RSX380 FE: Wood Outrigger Kit with Fiberglass Cowl (38" 965mm)
1 of 6
Product ID ml-rsx380
Price$239.99
Zipp Kits JAE 21FE v2: Wood Outrigger Kit  (33" 838mm)
Product ID zip-6513
Price$119.99
Speedmaster Bushing 3/16" for Sport 20 & 21 Style Strut
Product ID ros-spds-014-bsf
Price$5.95
Speedmaster Bushing 1/4" for Large Struts
Product ID ros-spds-015-bsf
Price$5.95
