OSE 1/4" Assembled, reverse cable with 1/4 to 3/16 step-down shaft. NOTE: This is REVERSED CABLE. The cable in this package is made for propellers that spin clockwise, like the Octura "R" series right props or the Graupner left props. Specs: Flex Cable diameter: 1/4 (.250", 6.35mm) Assembled length: 32" (800mm) Specs of the prop shaft, see picture 3 Shaft total length: 4.25" (108mm) Propeller shaft diameter: 3/16" (4.75mm) Propeller shaft length: 1.75" (44.4mm)
Requires:Drive Dog, 3/16" for large hub props you can put on a 1/4" drive dog on the 1/4" section.Prop Nut with 10-32 thread.Teflon tubing 1/4" size
Note:The OSE listed length is the total assembled length. Measured from the end of the cable to the tip of the propeller shaft. Flex cable lengths are approximate. They can be plus or minus one-half inch. These assemblies require the customer to cut the cable to its required length.
