K&S Brass Tubing, 36" (approx 900mm) in length. Sizes are listed in outside diameter (od). This tubing is used when building a stuffing tube system in a boat. There are two traditional ways to build a stuffing tube using a flex cable, either with a Teflon liner installed into the brass tube OR without a Teflon liner. If you search online you will find pros and cons to both solutions. Below you will find the recommended brass stuffing tube sizes for both methods.
Includes:(1) 36" (900mm) Length of Brass Tubing Only. No Teflon included.Note: Pictures 2 & 3 for reference only. One tube per package. Tubing will telescope into the next larger or smaller size. This is useful for making bushings, sleeves or drive shafts. See pictures 2 & 3. Loctite sleeve retainer glue is recommended for gluing brass tubing together.
