Large Offset Catamaran Strut and Rudder SystemOffset aluminum rudder and strut system for Catamarans with a built-in rudder water pickup. Features a nylon break-away bolt on the rudder to reduce damage when hit by submerged objects.The mounting plate measures 30mm (1.18") wide x 24mm (.95") tall.The leading edge of the rudder blade measures 87mm (3.42")Includes: - .187" (4.75mm) Flex Cable with 3/16" (4.75mm) shaft and 7mm Stuffing TubeThe system includes the following hardware:(1) aluminum rudder (1) aluminum strut with an installed 3/16" Lead Teflon Bearing Sleeve. (1) 3/16" flex cable with 7mm Stainless Stuffing tube with teflon.
Requires:Requires the customer to cut the flex cable to the required length. Note: This is similar to tfl-502b35, but it is designed for larger hulls. Picture 3 shows the hardware on the back of a 34" (865mm) TFL Cheetah. Boat not included!
