Speedmaster 1/4" Gas Strut and Square drive cable system
Product ID ros-SPDSD2-G250
In Stock 0
List Price: $179.99
Price: $159.95
Speedmaster Gas Strut and Square drive cable system.  It can be quickly adjusted from positive to negative thrust angles with the included 4mm titanium turnbuckle. Has a 3 Bolt Transom Bracket and Comes with a 24" Square Drive Cable
Comes with a 1/4" square drive Shaft, & a 3 Bolt Transom Bracket. Includes a 24" 1/4" Square Drive flex Cable and has a 4mm Titanium Adjuster Turnbuckle.
Specs:
Length Approximately 6" to Prop Tips.
Round Bottom with 1/4 Brass Bushing.
Mounting plate measurements: Width 39 mm, Height 58 mm
It is constructed from high-quality aluminum and CNC-machined to tight tolerances.
Includes:
(1) Speedmaster Gas drive in 1/4 Drive
(1) 1/4" square flex cable
Requires:
.250(1/4") Strut requires K&S# 8133 5/16" brass stuffing tube.
Note: Picture 4 shows this installed on a mono. The turn fins and other items in that picture are not included.
Octura 1/4 (.250, 6.35mm) Left Lay Cable : One Square End
1 of 2
Product ID oct-oc8sq-L-24a
Price$7.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
K&S Brass Tubing 36" long (915mm)
1 of 4
Product ID ks-brass-tb-36
Price$7.99
Octura 1/4 (.250, 6.35mm) Right Lay Cable : One Square End
1 of 2
Product ID oct-oc8sq-R-24a
Price$7.99
Speedmaster Bushing 1/4" for Large Struts
Product ID ros-spds-015-bsf
Price$5.95
