4mm Flex Shaft assembly with 4mm flex cable. Specs: Length from end to end is 350mm Flex Diameter: 4mm Prop shaft diameter: 4mm Prop shaft length: 70mmRotation: Left Cable NOTE: We have learned that there are 2 versions of cables available for the Arrow. This cable fits the TFL Arrow V2 Rigger. This is a larger and heavier cable. This is cable replaces cables in TFL Arrow rtr boats bought after October 2022. Please check sizes BEFORE Purchase to make sure this matches what you have. Requires: 4mm Drive Dog.
