TFL Arrow Outrigger RC Boat in Carbon Fiber: ARTR (Almost Ready to Race)This is the same as the Fiberglass Tfl arrow but now in Carbon fiber. If you are looking for an extremely fast boat that turns almost as fast as it goes in the straights, you found the right one. This boat comes assembled with all high-quality equipment. The new V2 version includes a thicker gauge 4mm flex cable. Specs: Hull Length: 24.2" ( 615mm) Width: 18.10" ( 460mm) Height: 2.56" (65mm) Weight: 500gramsCarbon Fiber Sponsons for lightweight and super strength.CNC aluminum hardware(see picture 7, 8 and 9). 125 Amp Esc, waterproof. TFL SSS 2958 (29mm diameter x 58mm long) 3300KV Brushless Motors. Metal propeller.Prop Shaft: 4mmFlex Cable: 4mm ARTR(almost ready to run). Requires: (1) Standard-size steering servo (1) Radio System(1) 3s 30c 2200 Lipo pack with EC5 connector and charger
