OSE Raider M40 Hull
These can be purchased in carbon fiber or Kevlar Versions.We specifically designed this hull at 40 inches to race in the Q-Class with 6s Lipo power, but don't let that fool you. This hull screams on 6s and is an absolute beast on 8s. The deep V design was created to handle turns and waves like no other boat on the market. The M40 can handle 6s to 8s with ease! The big open cowl/hatch provides plenty of room to work without having to struggle to fit batteries and parts. Pictures 6 & 7 show the inside and transom. Available in:- Black carbon weave.- Green & black carbon weave. - Light blue & black carbon weave.- Red & black carbon weave.- Kevlar weave. Specifications: Length: 1005mm (39.62") Beam: 300mm (11.75")Depth: 175mm (6.90") Bare Hull Weight: 1.36kg (2lb 15 oz) approx.
*** The picture and video depict the finished hull; they do not include any hardware, electronics, etc. Just a bare hull*** ***All Carbon hulls are hand-laid, meaning there may be slight irregularities in the weave***These can be made in many different ways. This is one of the many parts lists that can be used.(1) Speedmaster 1/4" 6090 Stinger pn# ros-stinger-str(1) Speedmaster Dual Pickup Tapered Rudder Assembly pn# ros-spdr-011a(1) 4-40 linkage rod pn# hh-4-40-3753(1) OSE Linkage rod connector ose-83106(1) DuBro Kwik Link for 4-40 Pushrod pn# hh-817(1) OSE 1/4" step-down cable. ose-cable-1290(1) OSE Drive Dog pn# ose-80246(1) Zuber prop nuts pn# ose-zn-8135 (1) K&S 5/16" brass stuffing tube. pn# ks-brass-tb-12(1) Speedmaster 3" trim tabs pn# ros-spdt-503(2) Speedmaster Large Mono Fins pn# ros-spdtf-100(1) TFL Rail motor mount pn# tfl-523b68(1) Larger T bar mount ose-83276 9/32" size (this will require enlarging to fit 5/16"(1) Castle Cobra Hydra Esc for 6 and 8s use pn# cas-010-0173-00(1) Leopard 4092 1480kv for 6s. Tenshock 2260 1350kv for 8s use. (1) Coupler 5mm to 250 flex or 8mm to 250 flex. It will depend on the motor you select.We recommend 8mm connectors. pn# ose-qs8-anti, Above are all the major parts, all the small stuff is not included, for example, connectors, glues, and Velcro.
