The Hydra Cobra 5 is based on our popular and powerful Hydra XLX2 ESC.
Free shipping with this item.
Specs:
- Measurements: See picture 4
- Continuous Amps: 200
- Connectors: Castle 8mm
- Burst Amps: 350
- Weight: 365 grams
- Waterproof: Yes
- Telemetry Capable: Yes
- Data Logging: Yes
- Auxiliary Wire: Yes
- Minimum Input Voltage: 3S
- Maximum Input Voltage: 8S
- Sensored Capable: Yes
- Recon G6 Certified ESC: No
- ROAR Certified ESC: No
- BEC: 5v to 8v, 20 Amps
- CRYO-DRIVE: Yes
CRYO-DRIVE™, Castle’s proprietary breakthrough technology, integrates unique software and dedicated hardware to reduce heat and dramatically increase performance. Thousands of times per second, the Cobra software minimizes the amount of time the electrical components spend generating heat. The results are more power handling, cooler ESC temperatures and longer runtimes, and ultra-high performance.
NOTE: Due to the high-power nature of the XLX2, you must use appropriately sized batteries and connectors. We recommend a minimum 150 amp connector for the Hydra XLX2; examples include Castle 6.5mm polarized, EC8, and QS8. DO NOT USE XT90, Traxxas, EC5/IC5, or any other connectors rated below 150 amps continuous.
You can easily optimize the ESC for any running conditions. Create, save, and download with the convenience of the new optional B-Link 2™ Bluetooth™ Adapter and Castle Link app for Android or iOS.
HYDRA Cobra 5 FEATURES:
- I32-Bit processing power for smoother motor control and improved response time.
- Enhanced Data Logging includes: Double the maximum sample frequency of older generations, 8x increased logging time of older generations, ESC electrical motor timing data, Acceleration data via onboard accelerometer, and the Looping feature prevents interruptions in data log recording.
| - Powerful Integrated 20A Peak BEC (5.5V-8.5V) adjustable in 0.1V increments.
- Additional tuning features include: Improved braking adjustability, Separate brake and reverse curves, and highly adjustable internal BEC. (5.0V - 8.5V adjustable in 0.1V increments).
- CRYO-DRIVE™ significantly improves thermal performance during partial throttle operation, where the majority of driving occurs.
- Auxiliary wire functionality for "on-the-fly" adjustments using your transmitter.
- 1-year warranty
