OSE 8.0mm Anti Spark Parallel Harness for use with ose-qs8-anti connectors. Using this will allow use of two batteries to double the system MAH but the voltage will be the same. Made with ose-qs8-anti connectors with 8 gauge wire.Includes: Everything in the picture. Note:Because runtime is doubled, its important to monitor heat buildup in the motor, esc and batteries. You must use two battery packs of the same exact specifications, age and quality. Failure to due so could cause a fire.
