Version 3 of the first 8mm Anti Spark that was released by OSE 10 years ago!OSE 8mm Anti Spark Female Connector System. Available in Black or Blue Housing. Anyone who's ever powered up an 8s or higher power system knows the dreaded spark that scares us all to death and at the same time ruins the connector. The bullet connector has an anti-spark housing that will reduce this spark to almost nothing. These are a must for high current/high voltage brushless power systems. Sold as a single Female connectorIncludes: (1) Female Antispark connector (1) Wire Cover Options:Black or Blue Housing
Specs: Diameter: 8.00mm Metal Material: Brass Plastic Material: Nylon with fiber. Flame retardant rating: UL94 V2 Temperature Range: -20C to +100CMax Voltage: 500v dc Continuous Current: 110A Peak Burst (2 to 5 seconds): 600aWeight: 20G per set. Length: 38mm including wire cover.Width: 27mm. Max Wire Diameter: 6.8mm (6AWG )
