OSE Qs6 Connector to EC8 connectors for a series battery connection. Using this will allow you to connect, two batteries with EC8 connectors to a ESC. Doubling the voltage to your esc/motor. Includes: Everything in the picture. (1) Qs6 red housing connector (2) Ec8 Connectors 10 Gauge wire Note: Using this will double the voltage of the system it's used in. You must use two battery packs of the same exact specifications, age, and quality. Failure to do so could cause a fire.
