OSE Raider 6s 150 Amp ESC with Qs6 connectors preinstalled for ease of installation. Designed with a large heat sink and dual water cooling tubes for superior cooling. Heavy 10-gauge wire and 4 capacitors. We custom-make the OSE Raider 150 ESCs using a Fly Color 150 as our base unit, then install the following to improve performance.- Extra capacitor bank for improved performance.- Longer motor wires- Preinstalled Qs6 6.00mm Bullet connectors on the battery side and OSE 6.00mm bullet connectors on the motor side.- And most importantly, the after-sales service from OSE within the USA. Instead of having to return things to China. We made this super easy to install for stock setups; we have installed an OSE Qs6 connector on the battery side with OSE 6mm bullet connectors on the motor side. See picture 1. This allows a plug-and-play ESC when combined with the Leopard Motors we sell (contact us if in doubt about your setup), while allowing more amp draw due to the larger OSE Qs6 connectors we use. We made this super easy to install with 2 connector options. - For modified setups, OSE-qs6p high-amp connector on the battery side with 6mm female bullet connectors on the motor side. See picture 2Using OSE 6mm bullet connectors on the motor side allows a plug-and-play ESC when combined with the Leopard Motors we sell (contact us if in doubt about your setup). This ESC is specially designed for use in RC boats. - Excellent waterproof design allows this ESC to work in wet conditions.- Optional LED Program Box for easy setting of all the ESC's parameters.- Low voltage protection. - Thermal protection, if the ESC goes over 100C (212F) the output will reduce to and not return to normal until the temperature reaches 80c (176F) or less. - Built-in BEC (battery eliminator circuit) to power your receiver. - Throttle signal loss protection. - Programmable for Forward with Reverse or Forward only.Specification: - Continuous Current: 150 Amps - Peak Current: 900 Amps. This is only for a brief second or so. - Wire size: 10 Gauge - Input: 2-6S (7.4volts - 22.2volts) Lipo - BEC Type: Switch Model - BEC Output: 5.5V/5A - Water cooling fittings: 5mm threads. - Weight: 215 Grams - Size (excludes the Water Cooling Pipe): 76mm X 56mm X 25mm - Connector: Battery side, Qs6 - Connector: Motor side: Female 6mm OSE Click here for full esc manual.
Click here for program box manual. Includes: (1) OSE Raider 150 Esc (3) Installed ose-6bullet connectors soldered onto the ESC motor end. (1) Installed ose-qs6p on the ESC battery end. Requires: Customers must have OSE QS6 high-amp connectors installed on their ESC. Note: This ESC was designed to work in an environment where it's possible for the ESC to get wet on occasion. Not for use underwater. OSE does not suggest using this item underwater! This ESC is suggested for smaller boats up to the 28"- 40" (700mm - 1000mm) range. Because there are so many variables with each hull and installation, it's impossible to specify all the applications for this ESC. If you have any questions about using this ESC with your particular boat, please contact us before purchasing.
