Zipp Kits G30 Tunnel Hull Kit : Wood kit with Cowl (30.5" 775mm) This is the new G30 Outboard Tunnel hull from Rod Geraghty and the JAE gang. Designed for Nitro or Electric power, this new kit features foam core sponsons and quick assembly. The G30 has been developed to a high level with stock 3.5 nitro and P limited electric power. Use any 3.5 (.21) outboard. The transom is drilled for the OS lower unit. You can build this boat in a weekend, ready for sealing.
Building the wooded structure requires the following:- Glue, sealer and paint. We recommend medium CA for the fuselage assembly, 30 minute epoxy for sponson assembly and epoxy finishing resin for sealing the entire outside of the hull.- Kipp Kits foam cutter. Specifications: Length: 30.5" (775mm) Beam: 11.5" (292mm) Weight: 32 ounces (bare) Kit Includes: - Laser cut 1/8 and 1/16 ply for entire boat - 2x Foam cores for sponsons - Engine mounting screws - Sponson nose blocks - Balsa fuselage nose block - Lightweight PETG (plastic) cowling- Step by step illustrated building and setup manual
Required for FE version:- 3.5cc outboard lower unit - 2 channel radio - 25Kg standard servo for steering (waterproof is best) - 3660mm 2050Kv Leopard motor with water jacket - OSE Raider 150A speed control - 4S 5000 mah battery (60C or higher) - cnc-4014250 - Servo mount ose-80090- Pushrod and connectors
Required for Nitro version: - 3.5cc Nitro outboard - 2 channel radio - 25Kg standard servo for steering (waterproof is best) - Mini servos for throttle and mixture - 8 ounce fuel tank and fuel line - 4S 5000 mah battery (60C or higher) - cnc-4014250 -Steering cables or pushrod (and servo mount) *Picture is of a painted and finished G30 Kit. This kit comes in laser-cut wooden parts that need to be assembled, glued and painted.
Build Video
