Leopard 3660 Motor
Product ID leo-3660
List Price: $59.95
Price: $49.95
Leopard 3660 brushless motor.
36mm Diameter by 60mm Long Brushless Motor by Leopard Power. Hand wound for high efficiency of up to 90%. Comes with high quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance.
2050Kv 2.5Y 5mm Motor Shaft
2550Kv 2Y
Specs:
Magnets: neodymium Watts: 800 with upto 1300 burst.
Poles: 4
Motor Shaft: 5mm
Can Measures: 36mm diameter x 60mm long
Weight: 251 Grams
Mounting Screw diameter required: 3mm
Bearing size: 5mm wide x 16mm od x 5mm id Flat
Spot on shaft for tightening coupler screw to.
Mounting Holes 25mm apart for use with most 540 mounts.
Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your esc connection.
Front and Rear vented end caps for additional cooling.
OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums.
 Works with OSE-80230-b Water Cooled Motor Mount.
1 Product Reviews - Average rating 5 / 5 (Show All)
Awesome motor
Tab - 22nd August 2023
2050kv in a 24" cat so far on 6s 74mph!
T-Jet Small Jet Drive by TFL
1 of 8
Product ID tfl-b54253-a
Price$69.99
TFL Outboard lower unit - Nitro or Electric ready!
1 of 6
Product ID tfl-542b40
Price$159.99
Adjustable Motor Mount for 28/36mm Motors
1 of 3
Product ID ose-80080-c
Price$10.95
Leopard 3640 Motor Water Jacket
Product ID leo-3640-jacket
Price$13.00
Leopard 3650 Motor Water Jacket
Product ID leo-3650-jacket
Price$13.00
Zipp Kits G30 Tunnel Hull Kit : Wood with Cowl (30.5" 775mm)
Product ID zip-g30-6516
Price$99.99
