New R4 Fast Electric Outrigger Kit (4S)
Completely new design for 4S power.
This boat was designed around a 4S pack and 36x56 or 36x60mm motor. Aimed squarely at P Limited racing, this is the most competitive hull out there.
The new sponson design by Tom David has tested very well so well, that Zipp Kits converted all of their existing outriggers to this state-of-the-art design!
All of the Zipp Kits outriggers were originally designed by IMPBA Hall Of Fame member Rod Geraghty. Rod is no longer with us, but his spirit lives on with the entire "R" series.This hull is the current state of the art for riggers, Designed for very low hydrodynamic drag with water shearing and anti-capillary features, this hull is fast, and turns are incredible!
Zipp Kits has reduced the amount of required sanding by 90%, so this kit builds very quickly. In fact, even if you have no building experience at all, this is an easy kit to build. Couple the easy building with it's record-setting performance, and you have a true winner!This is considered a full kit, as it includes carbon boom tubes, aluminum boom tube sleeves, boom tube collars, cowling, and a Pre-Sharpened aluminum turn fin with mounting hardware.
Specifications:Length: 30 inchesBeam: 20 inchesWeight: 5.0 to 7.5 poundsMotor: Upto a 36x60mm inrunner motorESC- 150-180 AmpRadio- 2-3 channel
Kit Includes:- Laser-cut Birch plywood for the entire kit.- CNC machined high-density foam sponson cores.- .093 Hardened PRESHARPENED aluminum turn fin with mounting hardware- .125 6061 Aluminum Motor Mount- Anodized aluminum sponson sleeves (4)- Carbon Fiber Solid boom tubes (2)- Aluminum boom tube collars (4)- Brass tub inserts for boom tubes (2)- Vacuum-formed PETG Stealth Cowling- 38 Page Photo Illustrated Building and Setup Manual
Requires:Suggested for 4s racing in P limited classes.Motor: Leopard 3660 2050kv motorESC: Raider 150Batteries: 4s 80c Lipo packServo Mount: ose-80090
Requires HardwareStrut: Jae 21 strutRudder: Speedmaster mini hydro rudderProp: cnc-4019250Servo: Standard SizeStuffing Tube:Cable: *Picture is of a painted and finished Zipp Kits R4 Rigger. Kit comes in wooden parts that need to be assembled and painted.
