TFL Aluminum Remote Controllable 1/4 Stinger Strut
Product ID tfl-503B92
In Stock 4
Price: $69.95
TFL aluminum 3rd channel remote adjustable 1/4-inch stinger strut. This strut can also be manually adjusted left or right to help offset torque steer.
In order to use remote adjusting, an additional servo must be attached to the arm on the strut.
Measurements: See picture 3
Length: 87mm (3.42")
Width: 40mm (1.58")
Height: 56mm (2.20")
Shaft 1/4" (6.35mm)
Includes:
Everything in picture 1.
Requires:
(1) High Torque servo
(1) Linkage rod
(1) Octura square cable oct-oc8sq-L-24a
(1) k&s Stuffing Tube 11/32" # 8134
(1) Teflon oc250t-24
Drive manual for reference
Transom Template for Drive
Octura 1/4 (.250, 6.35mm) Left Lay Cable : One Square End
1 of 2
Product ID oct-oc8sq-L-24a
Price$7.99
K&S Brass Tubing 12" long (305mm)
1 of 5
Product ID ks-brass-tb-12
Price$0.99
Teflon Liner 24" (600mm)
Product ID oct-teflon-24
Price$3.99
Recently Viewed
Pick up where you left off.
