TFL aluminum 3rd channel remote adjustable 3/16 inch stinger strut. This strut can also be manually adjusted left or right to help offset torque steer.To use remote adjusting, an additional servo must be attached to the arm on the strut. Measurements (picture 5): Length: Strut length 75mm Width: 33mmHeight: 40mmShaft 3/16" (4.75mm)Includes:Everything in picture 1.
Requires:(1) Servo with measurements of 31mm x 16mm x 30mm(1) Cable with 3/16" Prop Shaft(1) k&s Stuffing Tube
The video below is for the larger 1/4" Strut. But they work similarly.
