Leopard 4082 & 4082 X2 Motors
Product ID leo-4082
List Price: $104.95
Price: $89.95
Leopard 4082 brushless motor.
The Leopard has been the standard in high-value, high-quality, low-cost motors on the market. Leopard has released a new version of the popular 1600kv and 2200kv sizes, called the X2. Same physical size & performance with different end bells and logos.
Includes a water Jacket with Leopard Motor Purchase!
40mm Diameter by 82mm Long Brushless Motor by Leopard Power. Hand-wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance.
Specs:
Magnets: neodymium
Watts: 2400 with Over 3500 Burst.
Poles: 4
Motor Shaft: 5mm with a flat spot
Can Measures: 40mm diameter x 82mm long
Weight: 445 Grams
Mounting screw diameter required: 3mm
Bearing size: 5mm wide x 16mm OD x 5mm ID
Mounting holes 25 mm apart for use with most 540 mounts.
Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your ESC connection.
OSE suggests 20,000-35,000 total rpm for boats. We suggest that most Fast Electric Boaters should run in the 25,000 RPM range for sport boating or the 30,000 RPM range for racing. These are only guidelines; if you don't know how to choose the right motor, please consult other members of the RC fast electric boating community or us either at a local club or on our OSE Forums.
If you are using the OSE-80600 or 80610 mounts, we suggest the leo-4050 water jacket. For mounts with no rear clamp, you can use the longer leo-4068 Water jacket.
3 Product Reviews - Average rating 5 / 5 (Show All)
Suitable for RC Drag boats
Paul Goddard - 01st April 2023
I used two of these on the old Graupner polystyrene Berkely style jet drive, which came with a 500 watt brushed motor. These are way too much motor, I actually wrapped the drives in carbon fiber yarn, partly for looks, mostly for strength. I tapped the read more
1600kv X2 75mph!!
amisol - 16th November 2017
This motor is remarkable. No heat issue at all. Here's a video of its performance: https://youtu.be/P7KSjBjxSu8
Great
Robin Ducker - 17th February 2017
Hard to fault. Good power. Make sure your ESC is up to it; the 2000 & 2200KV motors draw BIG currents.
How-To Guides Using This Part
Brushless Motor timing
All how-to articles
OSE Leopard 4082 Motor & Raider ESC Package
Product ID ose-4082-R-Combo
Price$169.99
T-Jet Large Jet Drive by TFL
1 of 6
Product ID tfl-B54270
Price$279.99
Carbon fiber heavy duty motor mount for 40mm motors.
1 of 3
Product ID tfl-523b67-carbon
Price$19.99
Rear motor mount clamp ring
1 of 4
Product ID ose-80600-RC
Price$6.99
Rear clamp motor mount for 36mm or 40mm Motor
Product ID ose-83005
Price$9.95
Leopard 4050 Motor Water Jacket
Product ID leo-4050-jacket
Price$12.95
Leopard 4068 Motor Water Jacket
Product ID leo-4068-jacket
Price$16.00
Leopard 4076 Motor Water Jacket
Product ID leo-4076-jacket
Price$17.99
Zipp Kits JAE 21FE v2: Wood Outrigger Kit  (33" 838mm)
Product ID zip-6513
Price$119.99
