Leopard Water jacket for the 4092mm Leopard Motors. The Leopard Red anodized aluminum water-cooling jacket is designed to bring water into direct contact with the motor and allow it to flow around it, maximizing cooling. Installation is a snap!Apply some oil to both your motor housing and O-rings, then slide on the jacket. Picture shows the jacket installed on a 4092 Motor(not included).
Specs: Outside diameter: 47mm Length: 76mm Long Note: This jacket will fit the 4092 Leopard motors with wires exiting the back of the motor.
