Rear clamp ring for 36, 37, 38 or 40mm motor. This is the rear motor clamp ONLY. Available: Anodized in Silver or Orange. 37 and 38mm rings are a lighter color orange. This can be used as a replacement part for your OSE & TFL Motor mounts.Some examples are, tfl-523b67-carbon, tfl-523b68, tfl-523b61, OSE-80200, OSE-80210, OSE-80600, OSE-80610 mounts which all require a 53mm wide center clamp.
NOTE: 36mm or 40mm Motor Clamp only, not the entire mount.37mm is for the TenShock Evo-2240-p-limited Motor that measures 37mm in diameter.38mm is for the TenShock Evo-22 Series which measures 38mm in diameter. Measures: 53mm Wide from screw hole to screw hole. Requires: ALL screws, 3mm. Comes with an orange clamp only. No mounting screws.
