Leopard 4074 X2 Motor
Product ID leo-4074-X2
List Price: $94.95
Price: $89.95
Leopard 4074 X2 brushless motor.
40 mm diameter by 74 mm long brushless motor by Leopard Power. Hand-wound for high efficiency of up to 90%.
Special while supplies last; includes a water Jacket with Leopard Motor Purchase!
Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance.
Available in two versions.
1750 Kv/rpm per volt 2.5Y
2650 Kv/rpm per volt 1.5Y
Specs:
Magnets: neodymium
Watts: 1500 with Over 2800 Burst.
Poles: 4
Motor Shaft: 5mm with a flat spot
Can Measures: 40mm diameter x 74mm long
Weight: 360 Grams
Mounting screw diameter required: 3mm
Mounting Holes 25mm apart for use with most 540 mounts.
Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your ESC connection.
OSE suggests 20,000-35,000 total rpm for boats. We suggest that most Fast Electric Boaters should run in the 25,000 RPM range for sport boating or the 30,000 RPM range for racing. These are only guidelines; if you don't know how to choose the correct motor, please consult other members of the RC fast electric boating community or us either at a local club or on our OSE Forums.
1 Product Reviews - Average rating 5 / 5 (Show All)
2650kv 62mph+
Amir Solati - 08th September 2020
These small motors have excellent bearings, and are quite powerful.
Ive tested several props on these, and they can handle big props prop, such as ABC 1915.
Video of it here doing close to 63mph on 4S on 32" mono: https://youtu.be/M5zcMRmv048
T-Jet Large Jet Drive by TFL
1 of 6
Product ID tfl-B54270
Price$279.99
Carbon fiber heavy duty motor mount for 40mm motors.
1 of 3
Product ID tfl-523b67-carbon
Price$19.99
Rear motor mount clamp ring
1 of 4
Product ID ose-80600-RC
Price$6.99
Rear clamp motor mount for 36mm or 40mm Motor
Product ID ose-83005
Price$9.95
Leopard 4050 Motor Water Jacket
Product ID leo-4050-jacket
Price$12.95
