Carbon fiber heavy duty motor mount for 40mm motors.
Product ID tfl-523b67-carbon
In Stock 20
List Price: $22.99
Price: $19.99
Carbon fiber, heavy-duty motor mount for 40mm motors.
Examples, are TP 40xx, Leopard 4074, 4082, and 4092 brushless Motors.
Fits 40mm diameter motors that are 60mm or longer in length.
The rear motor clamp helps carry the weight of the heavier/longer 40mm motors. The angle is adjustable to allow straight alignment with the propeller cable.
The anodized aluminum mounting plate with extended Carbon fiber mounting stands distributes the motor's weight over a larger area for added strength. The mounting plates have holes drilled in the bottom to allow epoxy to flow into them, forming a superior bond with the hull. This mount can fit a vee bottom or similar hull. It will require modifying to fit a flat mounting area like a rigger or hydro.
Applications:
Fits most 40mm motors that are 60mm or longer.
 For example, Tp40xx, Leopard 4065, 4074, 4082, and 4092
NOTE:
Up to a 50 mm long water jacket can be used with 74mm & 82mm long motors.
Up to a 68 mm-long water jacket can be used with 92mm-long motors.
Measures:
Total width of 58mm including the mounting stands.
Metal center mounts measure 53mm wide.
Requires you to provide motor mounting screws.
Comes with a mount only.
Tenshock Evo 2270 "High Power" Version (40mm x 99.5mm long) :
1 of 4
Product ID ten-evo-2270-HP
Price$319.99
36mm Quick Change motor adapter for 36mm diameter motors
Product ID tfl-523b46a-bk
Price$16.99
40mm Quick Change motor adapter for 40mm diameter motors
Product ID tfl-523b47a-bk
Price$16.99
Leopard 4074 Motor
Product ID leo-4074
Price$79.95
Leopard 4074 X2 Motor
Product ID leo-4074-X2
Price$89.95
Leopard 4082 & 4082 X2 Motors
1 of 3
Product ID leo-4082
Price$89.95
Leopard 4092 Motor
1 of 2
Product ID leo-4092
Price$94.95
