TP 4060 Motor (measures 40mm x 92mm)
Product ID tp-4060-v1
Price: $128.95
TP Power Brushless 4060 V1 Motor (measures 40mm x 92mm)
Special while supplies last! Water Jacket included with TP Motor Purchase!
40mm Diameter by 92mm Long Brushless Motor. Hand wound for high efficiency of up to 90%. Comes with high quality bearings and neodymium magnets for high power. Large vented front and rear endbells for additional heat dissipation.
V1 Motors are the Newest design, a three piece can design with front and back end plates screwed on.
Specs:
Magnets: neodymium
Watts continuous: 3050
Watts max: 6200
Poles: 4
Motor Shaft: 5mm with flat spot
Can Measures: 40mm diameter x 92mm long
Aproxx weight (varies with wind choice): 455 Grams
Mounting screw diameter required: 3mm
Bearing size:
 Mounting Holes 25mm apart for use with most 540 mounts.
REQUIRES:
Bullet connectors. We suggest the OSE 5.5 Bullets.
 OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums.
2 Product Reviews - Average rating 5 / 5 (Show All)
Rrrrt
john a mcconnie - 05th July 2024
What a can this motor handle. My question can I run 12 s. With this motor. 1050 kv.
Superb
Robin Ducker - 17th February 2017
Hard to fault. Super smooth, silky power. Make sure your ESC is up to it; these 1650KV and up motors draw huge currents. What I like about them is the sound - its a super smooth purr that makes your hull sound great. Be careful with the cooling jacket - Iread more
