Sale, Normally $109.95TP Power Brushless 3650 V1 Motor (measures 36mm x 86mm) 36mm Diameter by 86mm Long Brushless Motor. Hand-wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power, and large, vented front and rear endbells for additional heat dissipation. V1 motors are a three-piece can design. Front and back plates screwed on. Specs: Magnets: neodymium Watts Continuous: 2350 Watts Max: 4500 Poles: 4 pole Motor Shaft: 5mm with flat spot Can Measures: 36mm diameter x 86mm long. Weight (varies with wind choice): 360 Grams Mounting screw diameter required: 3mm Bearing size:Mounting Holes 25mm apart for use with most 540 mounts.
REQUIRES: Bullet connectors. We suggest the OSE 5.5 Bullets. OSE suggests 20,000-35,000 total rpm for boats. We recommend that most Fast Electric Boaters run in the 25,000 RPM range for Sport Boating or the 30,000 RPM range for racing. These are only guidelines; if you do not know how to pick the correct motor, please consult other members of the RC fast electric boating community or us first, either at a local club or on our OSE Forums. *Notes: length and weight will vary with the selected wind.
