TFL P1 Drive System with 2960 Motor
Product ID tfl-b42515
List Price: $249.95
Price: $219.99
TFL P1 Aluminum outdrive system
Available in Red or Titanium anodized coating/color.
This high-quality CNC-designed drive system utilizes a set of straight gears and a drive dog-style coupler to the motor.  Adjustable manual trim angle.
Suggested for boats in the 25-35" range.
Click here for a detailed drawing.
Includes:
Everything in the picture.
(1) SSS 2960 Motor 2200kv and water jacket
(1) Outdrive
(1) 36mm bronze propeller
Specs:
4mm Prop Shaft.
385 Grams including motor.
Note:
Can be used in reverse with optional Right-handed ABC, CNC, or Octura props and ose-83400 adapter 4mm to 3/16".
Requires:
- Boat
- (2) 2mm steering rods
- (1) Esc 3s, 90 to 120 amps
- (3) 4mm Female bullet connectors.
- (1) 3s 40c 4000 to 5000 mah lipo pack
10 Product Reviews - Average rating 4.4 / 5 (Show All)
bearing upgrade
mike - 14th June 2023
Ordered bearings from BOCA to replace the factory bushings. WHAT A DEFFERENCE! It sounds so much smoother and got a few more RPMs.
Beautifully make. Good power.
curt - 26th October 2018
Beautifully made. Need complete disassembly before running. Several items must be addressed. As shipped all screws are loose, gear mesh was off, top gear cover not sealed, set screws must be tightened and have thread locker applied. Mine leaked lots ofread more
2 More TFL Drives to test
Steven F. - 23rd October 2018
These drives are great. However they do require that they are dis-assembled to lock-tite some of the set screws before use. This is quite easy to do. Be very careful to re-set the gear mesh for the upper gears. This is because the lower unit is mounted wread more
question
dmontecino - 15th February 2017
could you put 2 of these motors in a 50 inch hull?
**** Response from Offshore Electrics Inc. ****
Please email us at [email protected] for tech info.
very good outdrive
avinash inalsingh - 04th August 2016
very strong outdrive..i had a few before offshore had them...strong and work very good..i saw a post where they said it had a hole on the top of the unit and water gets in the gears..what you need to do is fill it up with a light gear oil and then put a sread more
water leak
rics fun vids - 01st July 2016
I put this drive in a Syma Century, but had issues with water getting in. After a little reverse pscycology. Found it was the hole in front of the upper gear cover allowing water vin thru the bellows. Plugged it. works great now.
Also got the reverse optread more
OSE Propeller Adapter
1 of 5
Product ID ose-83400
Price$1.99
Linkage Rod & Swivel Ball Connector: 2mm
1 of 2
Product ID tfl-519b80-a
Price$6.99
2-56 Linkage Rod (1.8mm diameter)
1 of 2
Product ID hh-2-56-3751
Price$1.49
OSE 4.0mm Bullet Connectors
Product ID ose-4mm-bullet
Price$1.49
OSE Raider 6s 90amp Esc with Ec5 connectors
1 of 2
Product ID ose-R-90
Price$49.99
P1 Drive Part : 10T Tapered Straight Gear A
Product ID tfl-b42515-04
Price$11.99
P1 Drive Part : 10T Tapered Straight Gear C
Product ID tfl-b42515-05
Price$6.95
P1 Drive Part : 10T Tapered Straight Gear B
Product ID tfl-b42515-06
Price$12.95
P1 Drive Part : 10T Tapered Straight Gear D
Product ID tfl-b42515-07
Price$6.95
P1 Drive Part : Stern Bearing Bracket
1 of 3
Product ID tfl-b42515-11-v2
Price$6.95
P1 Drive Part : Stern Bearing Bracket with bearings and thrust bearing
1 of 2
Product ID tfl-b54210-e
Price$14.99
P1 Drive Part : P1 Stern Bushing
Product ID tfl-b42515-12
Price$1.95
P1 Drive Part : P1 Stern Steering Knuckle
Product ID tfl-b42515-13
Price$2.75
P1 Drive Part : P1 Stern Dog Bone Shaft
Product ID tfl-b42515-14-15
Price$7.95
P1 Drive Part : Drive Dog for P1 & Scale TFL Outboard
Product ID tfl-b42515-16
Price$2.95
P1 Drive Part : P1 Main Mount, silver anodized color
Product ID tfl-b42515-19
Price$29.95
P1 Drive Part : P1 Trim Tap in Red anodized color
Product ID tfl-b42515-20-red
Price$9.95
P1 Drive Part : P1 Trim Tap in Titanium anodized color
Product ID tfl-b42515-20-ti
Price$9.95
P1 Drive Part : P1 Gear drive set
Product ID tfl-B42515-G
Price$33.99
P1 Drive Part : P1 Vise Mount in Red anodized color
Product ID tfl-b42515-22-red
Price$17.95
P1 Drive Part : P1 Vise Mount in Titanium anodized color
Product ID tfl-b42515-22-ti
Price$17.95
P1 Drive Part : P1 Stern 3.2 Steering Knuckle
Product ID tfl-b42515-33
Price$2.95
P1 Drive Part : P1 Linkage Rod Sleeve
Product ID tfl-b42515-34
Price$2.95
P1 Drive Part : Spacer / Shim
Product ID tfl-b42515-36
Price$1.00
