New TFL CNC Aluminum Outboard Motor Leg for nitro enginesIncludes a 3/16 (.187) propeller shaft and a .150 Left Rotating Cable.Specs: Length: 200mm (7.87")Width (At Widest Point): 70mm (2.76")Height: 133mm (5.24")Weight: 260.82 Grams (9.2Oz)Mounting Bracket Specs:Length: 48.50mm (1.91")Width: 48.50mm (1.91")Note: Some assembly required, 44mm maximum propeller diameter. Optional linkage rods and parts, links listed below:(1) package tfl-519b81-a(2) mc-94205a220 (m3)(2) mc-91292a123 (m3 - 20mm long)(20) ose-83112 for the connection to the servo horn (many require drilling your servo horn)
