OSE High Power Cable System for Traxxas M41
Product ID ose-cable-system-m41
Price: $59.95
OSE High Power Cable System Traxxas M41 Catamaran.
- This Upgrade works with your Traxxas M41 Catamaran to convert it to a much stronger 3/16" (.187", 4.75mm) cable and shaft system.
- Works in the stock Traxxas Stuffing tube.
Traxxas built the M41 with a 5mm propeller shaft and .150 cable. This limits the power you can use. Most increases in power cause the stock cables to twist and break.
We built this strut in standard 3/16" size and included two installed lead Teflon bushings (part# oct-oc6ltsb) for added prop shaft support. This strut is an absolute must for customers running modified motors with their M41's.
Includes all the parts needed to make the upgrade (everything in picture number 1)
Includes:
OSE-83274 strut with two installed oct-oc6ltsb lead Teflon bushings.
OSE-M41-Cable
OSE-81518 5mm-187 Coupler
2 Product Reviews - Average rating 5 / 5 (Show All)
Must have upgrade!
Jamie P. - 25th October 2022
This upgrade made me want to use my M41 again. Such an improvement over the stock shaft!
Thicker cable
Mark Fielding - 31st July 2019
This cable is way thicker and smoother than the stock Traxxas cable. I haven't broken a cable or lost a prop since I change to this system.
OSE Strut for Traxxas M41 to convert to 3/16": Strut Only
1 of 2
Product ID ose-83274
Price$19.95
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
OSE Heavy Duty upgraded Traxxas m41 HD Cable
Product ID ose-cable-HD-m41
Price$39.99
