OSE Traxxas M41 Catamaran 3/16" Propshaft Strut Upgrade for use with 3/16" (.187", 4.75mm) Prop Shafts. Available in blue or silver color.Note: This will not work with the stock M41 Cable!
-Upgrade your Traxxas M41 Cat to a much stronger 3/16" (.187", 4.75mm) cable and shaft system.-Works in the stock Traxxas Stuffing tube.
Traxxas built the M41 with a 5mm propeller shaft and .150 cable. This limits the power you can use. Most power increases cause the stock cables to twist and break.
We built this strut in standard 3/16" size and included two installed lead Teflon bushings (part# oct-oc6ltsb) for added prop shaft support. This strut is an absolute must for customers running modified motors with their M41's. Includes: OSE M41 strut ONLY. Includes two installed oct-oc6ltsb lead Teflon bushings.Requires:OSE-187L CableOSE-81518 Coupler
