Upgraded Traxxas Spartan Strut for use with 3/16" (.187", 4.75mm) Propeller Shafts.
Traxxas built the Spartan with a 5mm propeller shaft. This limits the availability of cables and shafts.
We built this strut in the standard 3/16" size and included two lead teflon bushings (part# oc6ltsb) for added prop shaft support. Then added a oiler/grease fitting for ease of maintenance. This strut is an absolute must for the customers running modified motors with the Spartans. This strut used in conjunction with the OSE-1190 cable and ose-81518 coupler will make a much stronger system. Includes: Strut ONLY, as seen in picture 1Picture 4 shows the complete ose-C-1405 cable system, THIS CABLE & COUPLER ARE NOT INCLUDED!
Requires: OSE-187LOSE-81518 Coupler These are available Blue anodized metal. Notes: Oil/grease fitting is a 4mm thread.
