OSE upgraded flex cable for Proboat Geico 29 V3 or BlackJack 29 V3
Product ID ose-cable-bj29-geico-v3
In Stock 3
Price: $39.99
OSE cable for the ProBoat BlackJack 29 V3 (ProBoat part number PRB08011) or Geico 29 V3 (ProBoat part number PRB08009). The version that comes stock with the 2000kv motors.
Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is higher quality, with thicker wire strands and better alignment with the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
No soldering or cutting is required!
This can also be used in any other boat requiring a .150 cable that measures 12.00" (305mm) (+/- .1") from tip to tip.
We suggest using part number oct-ocfhe5mm15D coupler with this shaft and the ProBoat Miss Geico 29 V3 or BlackJack 29 V3.
