OSE upgraded flex cable for ProBoat Miss Geico 29" V1
Product ID ose-cable-geico29-v1
In Stock 1
Price: $39.99
This is for the 29" single-motor version of the Miss Geico.
Upgraded .150" Cable with 3/16" prop shaft.
This is cut and ready to install in your boat. This upgraded cable is of higher quality with thicker wire strands and is better aligned to the prop shaft than the stock unit. The prop shaft is only 2 1/4" long, which reduces resistance and allows more strut adjustment. This will help reduce vibrations, which will help reduce strut bearing wear. Just install it and go! This is for a 4s setup. For a 6s lipo, use the HD cable.
This can also be used in any other boat requiring a .150 cable that measures 12.75" (325mm) (+/- .1") from tip to tip. No soldering or cutting is required!
Includes: Teflon Liner, cable with prop shaft, and attached drive dog.
