OSE heavy duty flex cable assembly for ProBoat Geico V3 & BlackJack V3. This is for customers with a heavily modified Geico V3 or BlackJack V3 that are using 4074 and 4082 motors. This cable is made with thicker gauge .187" Cable assembled to a 3/16"(.187) prop shaft and bullet nut. The cable we use is over 20% thicker than the stock ProBoat cable. This is cut and ready to install in your boat (requires ose-81518).
No soldering or cutting required!
NOTE: This will NOT fit a Stock Geico V3 or BlackJack V3 boat without the following additions. Requires: ose-81518 5mm to .187 Coupler and removal of stock proboat Teflon liner.
