OSE Flex Cable Assembly for the ProBoat Impulse 31. Upgraded .150" Cable with 3/16" prop shaft. This is cut and ready to install in your boat. This upgraded cable is a higher quality with thicker wire strands and better aligned to the prop shaft then the stock unit. The prop shaft is only 2 1/4" long which reduces resistance and allows more strut adjustment. Which will help vibrations which will help reduce strut bearing wear. Just install it and go!
No soldering or cutting required!
This can also be used in any other boat requiring a .150 cable that measures approx 8 3/8" (212.7mm) from tip to tip.
Includes: Teflon Liner, .150 cable with 3/16" prop shaft and attached drive dog and streamlined bullet nut.
