OSE Heavy Duty upgraded flex cable for ProBoat Impulse V1
Product ID ose-cable-HD-Impulse31-V1
In Stock 2
Price: $39.99
OSE Impulse 31 V1 heavy duty flex cable assembly.
This is for customers with a heavily modified ProBoat Impulse 31 boats that are using 4074 and 4082 motors. This cable is made with thicker gauge .187" Cable assembled to a 3/16"(.187) prop shaft and bullet nut. The cable we use is over 20% thicker than the stock ProBoat cable.
 This is cut and ready to install in your boat (requires ose-81518).
No soldering or cutting required!
NOTE: This will NOT fit a Stock Impulse without the following additions.
 Requires: ose-81518 5mm to .187 Coupler and removal of stock proboat Teflon liner.
This can also be used in any other boat requiring a .187 cable that measures approx 8 3/8" (212mm) from tip to tip.
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
