TP Power Brushless 4050 V1 Motor (measures 40mm x 82mm) Special while supplies last! Water Jacket included with Motor Purchase! 40mm Diameter by 82mm Long Brushless Motor. Hand wound for high efficiency of up to 90%. Comes with high quality bearings and neodymium magnets for high power. Large vented front and rear endbells for additional heat dissipation. V1 Motors are the Newest design, a three piece can design with front and back end plates screwed on. Specs: Magnets: neodymium Watts Continuous: 2350 Watts Max: 5000 Poles: 4 pole Motor Shaft: 5mm with flat spot Can Measures: 40mm diameter x 82mm long Approx weight (varies with wind choice): 420 Grams Mounting screw diameter required: 3mm Bearing size: Mounting Holes 25mm apart for use with most 540 mounts.
REQUIRES: Bullet connectors. We suggest the OSE 5.5 Bullets.OSE Suggests 20,000-35,000 total rpm for boats. We suggest most Fast Electric Boaters should run in the 25,000RPM range for Sport Boating or 30,000RPM Range for racing. These are only guidelines, we suggest if you do not have the knowledge to pick the correct motor, please consult us first or other members of the rc fast electric boating community. Either at a local club or on our OSE Forums.
