100mm long water jacket for 56mm Diameter Motor This aluminum water cooling jacket is designed to allow water to come in direct contact with the motor and flow around it allowing maximum cooling. Options:Silver or Black in color Installation is a snap! Apply some oil to both your motor housing and o-rings, then slide on the jacket. Fits: TFL SSS 56mm Diameter motors. For example the TFL-56114
Specs: Outside diameter 65mm. Length 100mm Long.*Motor not included
