75mm long water jacket for 56mm Diameter, Fits TP 5680 v1 & TFL SSS Motors. Options:Silver or Black in Color. This aluminum water cooling jacket is designed to allow water to come in direct contact with the motor and flow around it allowing maximum cooling. Installation is a snap! Apply some oil to both your motor housing and o-rings, then slide on the jacket. Fits: TP-5680-v1, TFL SSS TFL-56104, TFL-56114 56mm Diameter motors. Specs: Outside diameter 65mm. Length 75mm Long.*Motor not included
