TFL Zonda one-piece flex cable with 5mm prop nut. This is to replace the 2 piece system that comes stock. Installing this cable will make greasing the cable much easier than the stock cables. Simply loosen the motor couple and the shaft will come out of the back of the boat without having to remove the strut. Some trimming of the cable may need to be done to fit your exact boat. These can be purchased in single left or right rotation. (See Picture 2) Specs: 3/16" (.187", 4.75mm) Flex cable soldered to 3/16" (.187", 4.75mm) prop shaft that is 85mm long. 272mm from end to end (+/-2mm) Slot milled for the drive dog grub screw. Requires: Ose-80248 tapered drive dogNOTE: These can be used most struts that require a 3/16" prop shaft.
