Speedmaster 21 Rudder Assembly w/ Extended Tee Bracket
Product ID ros-spdrs-009-21
Price: $59.99
Made of high-quality aluminum, CNC cut to tight tolerances. Each assembly has a breakaway brass screw in the rudder bracket to help minimize damage from the blade hitting an object while driving. Comes with basic mounting screws. Features an extended tee mounting bracket.
Available in Two Options:
Rudder Assembly with Single Pickup Blade, pn# ros-spdrs-009-21sngt
Rudder Assembly with Dual Pickup Blade, pn# ros-spdrs-009-21dut
Specs:
Total Weight: 85.04g (3oz)
Rudder Blade:
Total Length: 158.75mm (6.25")
Leading Edge: 133.25mm (5.25")
Width: 4.65mm (0.18")
Mounting Plate:
Length: 25.5mm (1")
Width: 28.5mm (1.12")
Bracket (Mounting Plate & Tee Bracket):
Setback: 89mm (3.50")
Dual Arm Control Horn for Small Speedmaster Rudders
Product ID ros-spdrs-002-ch
Price$15.25
Speedmaster rudder water fitting 8-32 thread
Product ID ros-spd-103
Price$2.95
Speedmaster Small Replacement Blade w/ Single Pickup
Product ID ros-spdrs-004
Price$22.45
Speedmaster Rudder blade : Optional Long : fits SPDRS Small Rudder Assemblies
Product ID ros-spdrs-004-21
Price$23.95
Speedmaster Small Replacement Blade w/ Dual Pickup
Product ID ros-spdrs-005
Price$24.95
Speedmaster Bearing Block Extension Bracket for Small Rudders Assembly
1 of 6
Product ID ros-bb-ext-sml
Price$24.99
Speedmaster Short Transom Bracket for 006,007,008,009 Assemblies
Product ID ros-spdrs-010-ab
Price$5.95
Tee Bracket for Speedmaster for 006,007,008,009 Assemblies
Product ID ros-spdrs-010-tb
Price$7.99
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
