Speedmaster 21 Rudder Assembly w/ Short Tee Bracket
Product ID ros-spdrs-006-21
Price: $54.99
Made of high quality aluminum, CNC cut to tight tolerances. Each assembly has a break away brass screw in the rudder bracket to help minimize damage from the blade hitting a object while driving. Comes with basic mounting screws. Features a short tee mounting bracket.
Available in Two Options:
Rudder Assembly with Single Pickup Blade, pn# ros-spdrs-006-21sngt
Rudder Assembly with Dual Pickup Blade, pn# ros-spdrs-006-21dut
Specs:
Total Weight: 73.70g (2.6oz)
Rudder Blade:
Total Length: 158.75mm (6.25")
Leading Edge: 133.25mm (5.25")
Width: 4.65mm (0.18")
Mounting Plate:
Length: 25.5mm (1")
Width: 28.5mm (1.12")
Bracket (Mounting Plate & Tee Bracket):
Setback: 60mm (2.35")
« Previous | Next »
Dual Arm Control Horn for Small Speedmaster Rudders
Product ID ros-spdrs-002-ch
Price$15.25
Speedmaster rudder water fitting 8-32 thread
Product ID ros-spd-103
Price$2.95
Speedmaster Small Replacement Blade w/ Single Pickup
Product ID ros-spdrs-004
Price$22.45
Speedmaster Rudder blade : Optional Long : fits SPDRS Small Rudder Assemblies
Product ID ros-spdrs-004-21
Price$23.95
Speedmaster Small Replacement Blade w/ Dual Pickup
Product ID ros-spdrs-005
Price$24.95
Speedmaster Bearing Block Extension Bracket for Small Rudders Assembly
1 of 6
Product ID ros-bb-ext-sml
Price$24.99
Speedmaster Short Transom Bracket for 006,007,008,009 Assemblies
Product ID ros-spdrs-010-ab
Price$5.95
Tee Bracket for Speedmaster for 006,007,008,009 Assemblies
Product ID ros-spdrs-010-tb
Price$7.99
Du-Bro Safety Lock Kwik Link for 4-40 Pushrod
1 of 2
Product ID hh-817
Price$3.49
