OSE flex cable for ProBoat Sonic 24 for 3/16" props
Product ID ose-cable-sonic-24
In Stock 0
Price: $39.99
OSE Flex Cable Assembly for the ProBoat Sonic 24 (pn# hh-prb-1992).
The stock propeller shaft fits odd-sized 3mm props. We made a drop in cable that will work with 3/16" propellers. This will not work with the stock plastic propeller. We suggest the CNC-4019250 prop. Link at the bottom of the page.
This is cut and ready to install in your boat. This upgraded cable is higher quality, with thicker wire strands and better alignment with the prop shaft than the stock unit. Just install it and go! No soldering or cutting required!
This can also be used on any other boat that requires a .150 cable.
NOTE: Propeller NOT included. WILL NOT WORK WITH STOCK PROP.
Includes:
Ose .150( 3.80mm) cable with oct-oc6150psL prop shaft 3/16" (.187, 4.75mm).
Drive Dog pn# TFl-518b22
Octura Bullet Nut Pn# oct-oc6pnmm
Octura slim nut.
Drive Dog for 3/16" (4.75mm) Prop Shafts : 8mm OD
1 of 2
Product ID tfl-518b22
Price$2.99
ProBoat Sonicwake Version 24" Self-Righting Brushless Deep-V RTR
Product ID hh-prb-1992
Price$319.99
Octura Brass Bullet Nut for 3/16" shaft (10-32 thread)
Product ID oct-oc6pnmm
Price$3.79
CNC High Pitched Aluminum Prop :  3/16 bore
1 of 3
Product ID cnc-xx19250
Price$19.95
