CNC High Pitched Aluminum Prop : 3/16 bore
Product ID cnc-xx19250
Price: $19.95
CNC Magnalium 7075 metal propeller. 1.9" Pitch Ratio. If you have used a similarly sized 1.4-pitch-ratio prop, this will be the next prop to test.
Size options from 40mm to 48mm diameter; see picture 3 for specs
Prop Recommendations
ProBoat Sonic 24, cnc-4019250: Upgrade will require pn# ose-cable-sonic-24.
ProBoat Blackjack 24 v2, cnc-4519250.
Traxxas Spartan, cnc-4519250.
Machine-cut to high tolerances, this prop is ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Left-hand rotation. These spin counterclockwise when viewed from the back of the boat.
Fits 3/16"(.187" 4.76mm) Smooth Bore Propeller Shafts.
« Previous | Next »
ProBoat Sonicwake Version 24" Self-Righting Brushless Deep-V RTR
Product ID hh-prb-1992
Price$319.99
OSE flex cable for ProBoat Sonic 24 for 3/16" props
1 of 2
Product ID ose-cable-sonic-24
Price$39.99
CNC High Pitched Aluminum Prop :  Reversed - 3/16 bore
1 of 3
Product ID cnc-xx19250-R
Price$19.95
