ProBoat Zelos 36 Twin Flex cable assembly (Left and Right cable). This works with the first version yellow Zelos pn# PRB08021. OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. The wire strands on this cable are a thicker gauge for added strength. No soldering or cutting is required. Includes: (1) Left and Right rotation cable with these parts installed. - Ose-80248 tapered drive dogs - Octura oc6pnmm prop nuts - Octura thin nuts NOTE: See picture 3 for which prop to use with which cable. A left rotation cable works with left-handed props, for example, prb282027, x442, x447 A right rotation cable works with right-handed props, for example, prb282028, x442R, x447R Props not included. Measures: 10.12" (257mm) from end to end
