OSE Heavy Duty upgraded flex cable for ProBoat Voracity 36
Product ID ose-cable-HD-voracity36
In Stock 1
Price: $39.99
OSE Heavy Duty Flex Cable for the ProBoat Voracity
 OSE .187" Cable with 3/16" prop shaft. This cable measures .187" (4.75) in diameter. This cable is cut and ready to install into a stock ProBoat Voracity 36 with no other modifications. Comes as pictures with bullet nut.
Benefits over stock cable:
Thicker gauge flex cable windings.
5mm longer flex cable for added grip within the stock coupler.
 Soldered end for both added grip within the coupler and help with unwinding of cable end.
No soldering or cutting required!
This can also be used in any other boat requiring a .187 cable that measures approx. 240mm(+/-2) from tip to tip.
OSE 5mm to 187 (4.75mm (.187 3/16) Coupler
Product ID ose-81518
Price$9.95
