Servo-controlled adjustable trim tab assembly. Picture 3 shows the CAD drawing of the tabs installed. Large size for boats in the approximate 35"(900mm) plus length range(depending on transom width).
Each tab measures approximately 50mm( 1.97") wide x 50mm (1.97") deep x 28mm (1.1") tall. (2) tabs per pack.Includes everything in the picture. No linkage or servos included.
*Note: The picture shows the item measured in inches.
