Leopard 5692 brushless motor.Special while supplies last; includes a water Jacket with Leopard Motor Purchase! 56mm Diameter x 92mm Long Brushless Motor by Leopard Power. Hand-wound for high efficiency of up to 90%. Comes with high-quality bearings and neodymium magnets for high power. Includes endbells that are assembled with screws for both strength and ease of maintenance. Specs: Magnets: Neodymium Watts: 3000 with Over 5000 Burst. Poles: 4 Motor Shaft: 8mm Can Measures: 56mm diameter x 92mm long Mounting Screw diameter required: 4mm Mounting Holes 30mm apart Bearing size: 8mm wide x 19mm OD x 6mm IDWeighs: 32 ouncesVented can for extra coolingIncludes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your ESC connection.
OSE suggests 20,000-35,000 total rpm for boats. We suggest that most Fast Electric Boaters should run in the 25,000 RPM range for Sport Boating or the 30,000 RPM range for racing. These are only guidelines; if you do not have the knowledge to choose the correct motor, please consult other members of the RC fast electric boating community or us first. Either at a local club or on our OSE Forums.
Pick up where you left off.
