Leopard 3674 X2 Motor
Product ID leo-3674-x2
Price: $74.99
Leopard 3674 X2 1900kv brushless motor.
36 mm diameter by 74 mm long brushless motor by Leopard Power. Hand-wound for high efficiency of up to 90%.
Comes with high-quality bearings and neodymium magnets for high power. Includes end bells that are assembled with screws for both strength and ease of maintenance.
Specs:
Magnets: neodymium
Watts: 1200 with up to 1900 burst.
Poles: 4
Motor Shaft: 5mm with a flat spot
Can Measures: 36mm in diameter. See picture #4 for size specifications.
Weight: 320 Grams
Mounting Screw diameter required: 3mm
Bearing size:5mm inner diameter x 14mm outside diameter x 5mm wide
Mounting holes 25 mm apart for use with most 540 mounts.
Includes Leopard 6.0mm male bullet plugs soldered to the motor and a matching set for your ESC connection.
OSE suggests 20,000-35,000 total rpm for boats. We suggest that most Fast Electric Boaters should run in the 25,000 RPM range for Sport Boating or the 30,000 RPM range for racing. These are only guidelines; if you do not have the knowledge to choose the correct motor, please consult other members of the RC fast electric boating community or us first. Either at a local club or on our OSE Forums.
If you are using the OSE-80200 or 80210 mounts, we suggest the leo-3650 water jacket. For mounts with no rear clamp, you can use the longer leo-3665 water jacket.
Adjustable Motor Mount for 28/36mm Motors
1 of 3
Product ID ose-80080-c
Price$10.95
Water jacket 36 x 60mm long : Available in Red or Black
Product ID tfl-532b41
Price$10.99
Leopard 3640 Motor Water Jacket
Product ID leo-3640-jacket
Price$13.00
Leopard 3650 Motor Water Jacket
Product ID leo-3650-jacket
Price$13.00
Leopard 3665 Motor Water Jacket
Product ID leo-3665-jacket
Price$14.95
