CNC 3214 Magnalium 7075 propeller.
Machine cut to high tolerances makes this prop ready to use right out of the box. The Magnalium 7075 alloy makes this material upwards of 30% stronger than standard 7075 aluminum.
Left-hand rotation. These spin counterclockwise when looking at them from the back of the boat.
Fits 1/8"(.125" 3.17mm) Smooth Bore Propeller Shafts.
| Diameter | Total Pitch |
| 32mm (1.26") | 1.76" |
NOTE for Traxxas Blast:
Requires Octura oct-ocgcss4 upgrade shaft to fit onto Traxxas Blast. Larger props will also require closer monitoring of motor and ESC heat.
