Brand New but Open Box, save $60.00Seal Series ESC : 300A OPTO 6s-14s ZTW SEAL Series 300 : OPTO 6s-14s : 300 amps : Lipo Brushless ESC Version 1.
The ZTW SEAL Series is designed specifically for RC Boat applications, featuring a waterproof design. They are constructed using aluminum, adding an attractive look and ensuring enhanced durability compared to their competition. The 300A ESC includes two water cooling pipes as well as customized heat sinks. However, the 300A ESC does not offer a built-in BEC, requiring an additional battery pack to operate the servo. To protect the boat, the ESC offers a power reduction when too hot and an optional Low Voltage Cutoff. For more specific information, see the specs below...
Specs: The waterproof design (rates as IP 67) allows this ESC to work in wet conditions. Continuous Current (A): 300 Amps Burst Current(A): 350 Amps Voltage: 18-42 NiMH: 6s - 14s Lipo Power Wire: 8 Gauge160mm-Red/160mm-Black Motor Wire 8 Gauge 160mm-BlackBattery Eliminator Circuit (BEC): None, requires RX pack or BEC Eliminator Circuit. The throttle works in both forward and reverse. Optional programming with LCD programming card. Case dimensions (not including wires): Length: 150mm (5.91") Width: 85mm (3.35") Height: 28.6mm (1.13") Weight: 640g (22.58 Oz)Water fitting thread size: m6 Includes: Everything in picture number one
Software Download Click Here Requires: Connectors, 8mm bullet connectors or larger. Note: This esc will require an optional receiver battery pack or optional external BEC circuit. This ESC was designed to work in an environment where the ESC can get wet on occasion. Not for use underwater. OSE does not suggest using this item underwater!! This esc is suggested for boats in the 40" (1000mm) plus range. Because there are so many variables with each hull and installation it's impossible to specify all the applications for this esc. If you have any questions about using this esc with your particular boat, please contact us before purchasing.
